Tweeter help
Hey i need to buy some tweeters but i dont know where to hook them up to. Should i buy a amp or something, anyone know what to do
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 409
You can run the tweeters off your deck.
Username: Geekbike
Post Number: 89
As long as you have the appropriate crossovers.
is a deck the cd player cause i can't find where to hook them up to
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 469
Most head units have crossovers already built in them. Yes, the deck is the cd playr. To run the speakers you will have to piggy back them off another set of speakers.. just splice them in.
Username: Geekbike
Post Number: 90
No, you can't do that.
Tweeters can only handle very high frequencies and they would most likely blow if run straight to the HU without a crossover to filter out frequencies below 3000hz or so. Very few high end decks are are able to have a tweeter wired to the deck. Nearly all other decks will put out frequencies to low for a tweeter to handle.
Username: Bootykang
Post Number: 24
ok so what sould i do, i have a 200 watt amp that i could hook them up to but i dont want to blow them
Username: Jonathan_f
GA USA
Post Number: 3736
What kind of tweeters do you have/plan to get? Most come with inline crossovers, be they simple ones.
