What should i get?
Username: Mfgirbaud05
Post Number: 104
i just ordered a RE SX 15" with a ported box to the RE recommended specs...and i am running it to a Hifonics BX1500D amp...i didnt get it yet so i dont know how it sounds but what are some good speakers to get so i can hear the words...i mostly care for the bass with the sub but i do want to hear the words good to...and should i get tweeters? if so what are some good ones? Sry i dont really know too much about speakers, just mostly subs..
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 481
With that sub, you will most likely need component sets.You gotta look at it this way, you will be running 1500 watts to one sub, and like 20 watts to your speakers? The sub is an SPL beast. Look at CDT, Infinity, and MB Quart for cheap comps, you'll also need to amp those speakers.
