Infinities
Shaw Shaw
can n e 1 find if infinity 1230's are dual voice coil or not
Username: Opie_har
Somewhere, One of them USA
Post Number: 54
Try google
Shaw Shaw
jon doe, is it true you have clamidia?
Username: Opie_har
Post Number: 56
That's the way for an unregistered guest to get a lot of help here.
Shaw Shaw
sure is carl
shaw shaw
are 2 10" jl audio w4's better than 2 12" infinity 1230's
Username: Opie_har
Post Number: 57
By the way, they are not dual voice coil.
Enlarge
Infinity 12" Subwoofer (1230W)
INI 1230W • 12" subwoofer
• 1200 watts peak power • Polypropylene cone
• 20Hz - 250Hz
Web Only Special
Price was: $99.99
You save: -$20.00
You pay: $79.99
Free shipping on orders $25 & up + Free in-store pickup on all orders
Highlights Customer reviews Specifications Accessories Click & Learn
Power
Peak power handling (watts) 1200
RMS power handling (Watts) Info unavailable
Frequency response (Hz) 20Hz - 250Hz
Impedance (Ohms) 4
Sensitivity (dB) 92
Design
Subwoofer size 12"
Dual voice coil No
Voice coil design Single Copper
Basket design Info unavailable
Basket material Stamped steel
Woofer cone material Polypropylene
Woofer surround material Rubber
Fs - free air resonance (Hz) 29
Vas (liters) Info unavailable
xMax - maximum excursion (millimeters) 12.5
QTS .54
Enclosure requirements
Mounting depth (inches) 6-1/4
Recommended enclosure type Sealed, Ported
Cabinet cubic foot recommended (ported/sealed) Info unavailable
Ported box volume (cu. ft.) 2.0
Port diameter (inches) Info unavailable
Port length (inches) Info unavailable
Sealed box volume (cu. ft.) 1.25
General features
Warranty Parts 12 Months
Warranty Labor 12 Months
All prices, specifications & items are subject to change without notice. Be sure to check our rebates section to see if there are any current rebates on these products. Prices in
Be careful you don't catch my clamidia!!!
Shaw Shaw
thanks carl, get crazy with the cheese whiz
Username: Opie_har
Post Number: 58
Who the Fu*k is Carl???? Your boyfriend and butt pirate???
Shaw Shaw
wow, ur a butt pirate carl? if ur gay thats fine but im not, take ur loose penis hole somewhere else carl or im telling your mom.
Username: Opie_har
Post Number: 60
Dude. My name is Jon. If you love Carl so much, the so be it. I am sure that you can find Carl on google. I am not Carl. I whistle when i f@rt, tighter than a frog's azz, and thats water tight!!!!
Shaw Shaw
ok, so ur the giver not the reciever... its still being gay. so, carl, back to car audio...
