Dual 2 ohm subs. help with wiring facts
vladee19
what amp would i need to power a single dual 2 ohm subs such as the avalanche. when wired down, what ohm will it present. will it be 4 ohm or 1 ohm. will a jl 1000/1 be a good amp to push this sub????
Username: Subfanatic
Walton, Ky
Post Number: 2729
that will be a fine amp as long as you knwo what your doing with your box, BUT if your using the 1000/1 it doesnt matter about your sub, its stable 1000 watts rms at 1-4 ohms i beliebve, but for futrue reference, a dual 2 sub can be wired in parallel to 1 ohm or in series to 4 ohms
vladee19
what do u mean wire in series. does this require more than one sub cause i'm going to be using only 1 avalanche sub.
Walton, Ky
Post Number: 2731
no it doesnt require more than 1 sdub, wiring in series is like lioke diong this
http://www.jlaudio.com/tutorials/wiring/index.html
vlad319
hey thanks alot for the fast post.
