Please help me decide?
Username: Kurt_114
Laredo, Tx USA
Post Number: 7
Its come down to one of these two options. For the same price I cant get:
2 Stage 1 Punch p115d4 15" w/enclosre
1 Kicker L7 15" w/out enclosure.
PLEASE HELP I NEED TO KNOW FAST. I Have a Focus sedan.
Username: Subfanatic
Walton, Ky
Post Number: 2329
go with the kicker, it will get alot louder, and you could build your own box or haveome eomeone eon here do it
Username: Insearchofbass
Post Number: 1338
l7 15 it will pound which im sure is what you want since you choose the kicker
Post Number: 1339
do a 4.10 cubic ft. box ported to 34 hz with two 4 inch ports 9.75 inches long and just drop the sub in youll pound
Username: Taylor17
Kopperl, Texas
Post Number: 1440
Yup, the l7 will be louder.
Post Number: 1340
correction two 4 inch ports 12.75 inches deep at 34 hz in a 3.75 cf box and drop the l7 15 in
Post Number: 1341
darn it i meant 4.10 cubic feet with two 4 inch ports 12.75 inches deep at 34 hz
Walton, Ky
Post Number: 2336
seean YOU SUCK
Username: Kurt_114
Laredo, Tx USA
Post Number: 8
THanx fellas you sure helped out a lot. Greatly appreciated. SO I'll just have a box made with those measurements, correct and it should Pound right?
Walton, Ky
Post Number: 2352
with seans it will get LOUD
