BOXES
4x20Lover4Life
Who here is an "expert" on making sub boxes? Just a few questions:
1) What is tuning a sub box?
2) How is it done?
3) Which is best between sealed, ported & bandpass
Username: Subfanatic
Walton, Ky
Post Number: 2991
i am, tuning a box is when it is ported or ventedand this is when u change lenght of the ports to different frequencies,
2 its done by changing the cubic inches of the port
3. slead is best for sq, ported is good for sq but best for spl, and bandpass is a pos
4x20Lover4Life
OK.. Is there a site that tells me how to port a box? What do i use for a port?
Walton, Ky
Post Number: 2996
www.bcae1.com this will do everything to teach you stuff, use PVC pipe, we can give you dimensions on here if u want including size of pvc and length of it and what dimensions for the box if u tell us your sub and the required frequenscy
4x20Lover4Life
Like, what pipe do I use?
4x20Lover4Life
Nevermind about the pipe, im slow. I'll get back to you about the sub and frequency.
