Amplifying 2000w sub
i hav a 2000w max SUB (12") and a 600w max AMP. i know this is not enuff to power the SUB so i am going to get another amplifier.
how do i connect 2 amplifiers to 1 sub???
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 319
you shouldn't look at the max ratings, what are the RMS ratings?? the only way to hook 2 amps to a single sub is if the amps are strapable or if the sub had dual voice coils, one amp per coil. but unless they are really good stable amps, i wouldn't recommend doing that.
