Atlas 15"
Username: Algirard1
OH United States
Post Number: 71
What amp should I run the Atlas 15" off of? I don't want to spend too much but I also want a good amp. I am looking at spending $300 max on the amp. Any suggestions.
Username: Basketballinu05
Post Number: 33
yeah same question here is the atlas 4 ohm or 2
Username: Pharoh
Bradford, Ontario Canada
Post Number: 146
put out and extra 50$ and buy a PG 600.1 Im running my 2 12 atlas off them and it sounds minty
Username: Insearchofbass
Post Number: 1342
yeah i really like the pg amps plus that should be decent for your charging system
Username: Pharoh
Post Number: 151
; ) Theres also the Kicker but i herdd it gets a lil warm sometimes
Post Number: 34
is the atlas 4 or 2 ohms?
Username: Terps297
Potomac, MD USA
Post Number: 102
svc 4 ohm the other voice coil is 2 ohm but it's used to adjust the Qts
