Bronze Member Username: Kalow_80Post Number: 11 Registered: Apr-05 | i am lookin at getting 2 12 inch subs.. the problem is selecting which ones to get.. could everyone please give me a list of like 5 subs that thay suggest.. my budget is 400-450 at the most for 2 12's thanks |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2294 Registered: Dec-04 | 2 12 inch atlases, 2 12 inch eclipse al 88100's, 1 12 inch x.x.x, 1 12 inch sx, 2 12 inch kicker comp vr's, 2 12inch p3's |
Gold Member Username: InsearchofbassPost Number: 1320 Registered: Jun-04 | id do one idmax 12d but you could do 2 ..heres the site to get them cheap $279 shipped http://www.carmedia1.com/ |
Bronze Member Username: Kalow_80Post Number: 13 Registered: Apr-05 | what do u guys think about MTX 5500 thunder.. or the JL 12 3w2v?? |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2299 Registered: Dec-04 | the jl is a ncie sub |
Gold Member Username: InsearchofbassPost Number: 1321 Registered: Jun-04 | the jl w3 v2 is a very nice sub for sq ive personally tested one in my vehicle with a 2.00 cf sealed box before the subwoofer was in and smooth is the word it peaked at 124 db in car before distortion it tends to need more than rated power in that box id do 400 rms to it if it was me |
Bronze Member Username: Kalow_80Post Number: 14 Registered: Apr-05 | but it does not have very good SPL? |
Gold Member Username: InsearchofbassPost Number: 1322 Registered: Jun-04 | its optimal sealed box size comes to 2.16 cf before the subwoofer. if you want to get more bottom end port it to 29 hz in the 2.16 cf box it should sound sweet there |
Gold Member Username: InsearchofbassPost Number: 1323 Registered: Jun-04 | you should pick up about 4 db ported there so id say 128 db ported but i also pick up 2 db with my windows down the 124 db was with windows up so i could peak 131 db with that sub windows down |
Gold Member Username: InsearchofbassPost Number: 1324 Registered: Jun-04 | opps i meant 130 db with windows down |
Gold Member Username: InsearchofbassPost Number: 1326 Registered: Jun-04 | 130 db is fine for an sq sub that cheaply priced |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2312 Registered: Dec-04 | wow sean, 4 posts in a row lol |
Bronze Member Username: Kalow_80Post Number: 15 Registered: Apr-05 | would you recommend this sub... did u like it and will 2 12's sound good? |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2313 Registered: Dec-04 | yea my friend has 2 12 inch w3v2's in his truck under the seats, very supurb subs |
Gold Member Username: InsearchofbassPost Number: 1327 Registered: Jun-04 | i really really liked the sound of this subwoofer absolutely no distortion i was impressed but that was on my mtx 81000d that puts out 1500 rms at 2 ohm...id say 400 rms would do nice with this sub...do the ported box i recomened this sub will shake stuff i had the legend cd in and at one point the bass hit but i couldnt hear it all that happened was as if it came through in three divided waves and shook i mean shook everything ported at 29 hz its gonna be even more impressive than my sealed box was because it will be about 4 db louder on the bottom end than it was in the sealed box |
Gold Member Username: InsearchofbassPost Number: 1328 Registered: Jun-04 | reminder.... its optimal sealed box size comes to 2.16 cf before the subwoofer. if you want to get more bottom end port it to 29 hz in the 2.16 cf box it should sound sweet there |
Gold Member Username: InsearchofbassPost Number: 1329 Registered: Jun-04 | the wierd thing was my lanzar dc 12s (original lanzars not pyramid) were at least 10 db louder in a sealed box than the single jl 12w 3 v2 was but i could hear it outside my car more than my lanzars....go figure |
