Enough Battery Power??
Blair
Q.1 I was looking at buying a Optima Yellow Top, 650 CCA rating. It will be providing power for a MTX 1501D and a MTX 4x85 watt (cant remenber the desc. no) Will this be enough or should I look at some thing bigger?
Q.2 Are the Stinger dry Cells any good?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7676
the yellow top is fine. you can reference the discharge time based on current draw on their website to see how long the battery will last with ~100A of draw.
the battery only helps if the engine is off.
when the car is running you'll want a HO alternator to handle the drain.
