Lookin for a Good Amp Kit
Username: Crazyfool289
Post Number: 7
im gonna be bridging a kicker kx850.2 to one 15" solo baric L7(2 ohm dual voice coil if that makes any difference...) What is a good 4 guage kit for this setup??? something that has everything i need and quality
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 311
pretty much power/ground wire is power/ground wire, not much difference. just don't use solid strand wire and oxygen free helps with interference. RCA's is where a good wire makes a lot of difference. try ebay, crutchfield sells it...anyplace online should be cheap
Post Number: 8
ok sweet so the brand probly isnt important. what all sould i look for to be included in the kit?
Username: Carguy
Post Number: 2403
Look for high strand power wires priced under $50. A fuse holder and fuse should come with the kit. As for rca cable, most of them included in the package are not worth using. So look else where for "twisted" rca cable. Don't spend over $30. Some of the nice ones are around $20.
