Quick question
Username: Araknid
BOCA , FL U.S.
Post Number: 435
is 460 watts RMS to much for a type R rated at 300 RMS if i put the gains down to lower then half.
Username: Thumper
Richmond, VA U.S.A
Post Number: 26
Turn the gain all the way down, Turn the volume up to waht you would normally listen to. Then turn the gain up. When it starts to clip back off a bit and ye should be good
