Quick question
Username: Araknid
BOCA , FL U.S.
Post Number: 436
is 460 watts RMS to much for a type R rated at 300 RMS if i put the gains down to lower then half.
Username: Carguy
Post Number: 2398
Gain/level is not a volume control. Set it correctly according to your HU.
460w is a bit too much for your sub, but use self control with the volume knob and you'll be fine.
