Idmax and hifonics brutus bx1500
Newbie101
2 id max 12D4
1 Hifonics Brutus bx1500
how would i go about to setting this system up what esle would i need. Money is no option
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 341
You should have gotten DVC 2 ohms so you could wire them to 1ohms to get the max out of the amp. Where did you buy them from? Try and return for the 2 ohms.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 342
If you can't do that, wire your subs in parallel to get 2 ohm loads.
Username: Invain
Michigan United States
Post Number: 2049
David what are you talking about. He can wire each sub to 2 ohms, and then wire them together to 1 ohm. It works fine for his amp. The hifonics is a monoblock. He doesn't want both subs to present a 1 ohm load, he wants a 1 ohm load TOTAL.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 534
I tihnk David i he has teh d4 versions. Which means he can wire it to a 1 ohm load. Just wire both in a 1 ohm load like the first option on this link. http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=13&image.y=12
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 359
Oh I see.
Username: Invain
Post Number: 2051
He does have dual 4 ohm drivers. That's what the "D4" stands for in the name.
Newbie101
alrite i didn't order the idmax's yet.. but im sold on buying them and hifonics.. hifonics from ebay and idmaxes from mmexpress. should i get the 2 ohm id maxes. also what kind of wiring and capriator should i get or watever i dont know wat i should do about taht
newbie101
Alpine receiver and iPod adapter in one package
CDA-9830 CD receiver would that aslo be a good receiver for my system
Username: Subfanatic
Walton, Ky
Post Number: 2170
no newbie, get the DUAL VOICE COIL 4 ohm version, that way you acn wire them all in parrelel and get a 1 ohm load for your amp to give each sub 750 watts rms, BUT if you do not mind me asking, if money is no option, why are you settling for this?
Newbie101
from what i been hearing idmaxs were some good subwoofers. now for a headunit for spl.
Username: Suleman36
Post Number: 660
How good of an amp is the Hifonics bx1500 or any other mono hifonics amps??
Newbie101
are idmaxes subs like perfect subs for rap music?
Username: Tpizzle
Post Number: 48
newbie where did you find those subs i cant find that company? also whats the price on those?
Username: Tpizzle
Post Number: 49
also are those IDMax or IDQ. im only findin D4 versions under the IDQ.
Username: Suleman36
Post Number: 663
YOu can find them on www.cardomain.com , they are the only authorized dealer for image dynamics plus they price match there competition. As for my last question i had. Anyone here know how good Hifonics bx1500 or any other mono hifonics amps are???
Newbie101
http://www.woofersetc.com/product.asp?0=301&1=304&3=1789 thats one sight i found.. i found them as low as 299 some wheere
Newbie101
i chose hifonics because i like the way the amp look and i heard a lot of good things about it
Username: Suleman36
Post Number: 665
How many amp fuse does this hifonic take??
Username: Invain
Post Number: 2062
Hifonics are alright if you have a pretty low budget. They don't have the greatest failure rate, and they over-rate their amps. Their definitely better than Sony, Boss, Pyle, etc., but if you can afford it I'd look into something different.
