Dumb question?
Username: Rhassler
Gilford, NH
Post Number: 129
i was just wondering...
say if someone has 2 jl audio w7's, and they hook them up parallel to the amp, that equals a 1.5 ohm load. Can any amp thats 1 ohm stable produce that load and you just have to figure out how many watts that amp would put out at 1.5 ohms?
Username: Jlprix91
West, Michigan Usa
Post Number: 67
If an amp is rated at 1 Ohm it can handle anything above, including a 1.5 ohm load
Username: 54danny54
Post Number: 213
then how would u get a .7 load like the MT
Username: Rob_brown
Post Number: 228
are w7's 3 ohms. cause if they are i think it woudl be a .75 ohm load because you take the 3 and divide it by 2 for the first sub, then by 2 again for the second sub. because they're in parallel. right?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1282
im confused. well the MT has many different coil configs, but there are amps that are .5 ohm stable.
Username: Alpineuser
Post Number: 211
can u get taste lose from a fooseball table?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1288
does a bear shiznit in the woods?
can you get mole.sted by a fooseball table?
yes and yes
