Amp for my 12" Atlas
Username: Tpizzle
Post Number: 84
I need help deciding on an amp for my 12" Atlas. i know it doesnt take much power. i have $200 any suggestions?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 401
Anything that will put out 250 watts. Look at PPI Art Series and PC/PCX series, they are awesome amps and would be a perfect match for that sub.
Username: Tpizzle
Post Number: 88
ide love to go with that quality but thier $400 amps. i need something under $200 that will run my 12" Atlas nicely. 250rms not sure about max. any suggestions for amps, how about hifonics, fosgate, or ???
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 992
http://www.etronics.com/product.asp?stk_code=sourub3002&store=&catid=303
300 watt rms @ 14 volts 4 ohm bridged or somewhere around 250 at 12.5v.
I own one. Its an older amd IMO "better", discontinued model and powered my 10w3's pretty good darn good when I gave it a go. I bought it primarally as a mid/high amp so if you you plan on eventually upgrading your sub/amp it'll do great on a set of components(75x2 @ 12.5 volts 4 ohms).
That thing listed at nearly 400 bucks and is a steal at $99. Etronics doesn't sell used or refurbished items so as far as a good "bang for a buck" amp I think its hard to beat.
-Fishy
Username: Tpizzle
Post Number: 94
any other suggestions im just looking right now until i get the sub. it is an Atlas 12" 250-300 rms nobody knows for sure. whats the best amp out there in this rms range for under $200?
Username: Fishy
Post Number: 1001
There's tons of good stuff out there. Which is "best" is pretty subjective. Just stay away from the flea market stuff. Here a list that might help:
http://www.caraudiocentral.net/forums/showthread.php?t=32
For two hundred dollars you might be able to pick up a good used monoblock which produces 600w at 2 ohm and 300w at 4. That way you'd be set for power if you ever wanted to upgrade:
Like this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573%26item%3D5769134386 %26
or this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796%26item%3D5768941714 %26
I've seen a few new, discontinued 600w Xtant A6001's(titanium color/edition) floating around ebay for around $200 which would work good as well.
-Fishy
Username: James1115
Wilton, Ct
Post Number: 2392
for a good clean power under $200 honestly this is one of the best amps ever made! http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950%26item%3D5767860225% 26%26
Username: Tpizzle
Post Number: 98
im having trouble finding the PPI are series, ebay only has 1. Where could i find more, what other amps would be great for a 12" Atlas?
