Need ADVICE On Best Head Unit For Under 200$
Username: Vincentian
Post Number: 15
hi... need advice on the best head unit for under 200 dollars ... ne input would be helpful thanks
Username: Invain
Michigan United States
Post Number: 2034
The lower Alpine models. Just look for ones with 982 as the first 3 of the 4 numbers in the model number.
Post Number: 16
aite thanks
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 345
Theres nothing wrong with Pioneers either. Before you buy, go to an audio store and demo some head units and check out which ones have the best optins that you like, then buy them online if the store won't match the price.
