Guys need your help
Username: Chevelle
Lancaster, Pa Usa
Post Number: 22
comming home from work and my amp it was pumping next thing i hear sounds like one speaker went then i heard a snap type pop and smelled like burning wire the fuse in the amp didn't blow or the inline fues.BUT THE AMP SMELLS BURNT it's a volfenhag zx-7180 this was pumping in a set of audiofonics 10" 2000w woofers need your help
Username: Chevelle
Lancaster, Pa Usa
Post Number: 23
the whole time i had it one time it was sounding good next time it didn't now i tested the woofers on another amp and they work so i guess i fryed the amp
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 293
if the amp smells burnt, then you burned up the amp. your inline fuse might of been too big. also, i haven't heard many good things about volfenhag amps, so that really isn't supprising
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 960
Yeah I'm not sure a Volfenhag is worth fixing either. Probably time to hit e-bay.
-Fishy
Username: Chevelle
Lancaster, Pa Usa
Post Number: 24
the fuse thats in it was the one that it came with 80 amp but it's still under warranty so i just send it back
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 355
Volfenhagen.. wonder how it lasted that long..
Username: Chevelle
Lancaster, Pa Usa
Post Number: 25
who makes these amps
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 358
Who cares, stay away from them.
Username: Chevelle
Lancaster, Pa Usa
Post Number: 26
i ask who makes them so i can get my money back
