Experienced decsion needed!!!
Username: Tpizzle
Post Number: 25
I need help deciding whether to buy 1 12" sub or 2 10". I only have $200 to spend so probably have to go with 1 12". i mostly want sq any recommendations? i have heard a lot about IDMax but its too expensive. how clean are 12" subs bass?
Username: Taylor17
Kopperl, Texas
Post Number: 1359
Get the JL w3, you might be able to find it for $180, and the sq is great, not to mintion it gets pretty loud as well!
Username: James1115
Wilton, Ct
Post Number: 2354
www.ascendantaudio.com :-) atlas 12 baby!
Username: Pharoh
Bradford, Ontario Canada
Post Number: 123
You love atlas..
Username: Insearchofbass
Post Number: 1279
the jl 12w 3 v2 does have very nice sound in a 2.00 cf sealed box internal but not an spl monster there. There was nothing that sounded like crap in that box and speaker combo i was impressed but id did seem to need more power than i expected it to need. All i can say is smooooooooooth.
Post Number: 1280
i was runnin it off my mtx 81000d amp ...and it hit so low that i couldnt hear the bass with the legend cd in on the one track but it was as if it broke through in 3 segments and shook i mean shook everything. if it was me id do an optimized large sq enclosure (larger than 2.00 cf) ported down to its 24hz fs frequency. And enjoy.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 339
I third the Atlas 12". Pristine.
Username: Invain
Michigan United States
Post Number: 2053
Don't forget about the newer Eclipse Aluminums, 7300 series. If you could find an 8800 series Aluminum, it would be great too. If you don't wanna spend all of that 200 bucks you could try the Adire Shiva; the new ones are out now, and their still onll $125.
