How big of a differance?
Username: Langner
Madison, South dakota US
Post Number: 83
how big of a differance in sound is there between 1 12" or 2 12" because i have no idea
Username: Subfanatic
Walton, Ky
Post Number: 2056
same subs, properly powered, then 3 db;s
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7585
actually about +6dB, since you have twice the drivers, and twice the power usually.
it's quite noticeable if you're adding a second identical sub, and giving it as much power as you gave the first sub.
Walton, Ky
Post Number: 2060
oh lol, sorry abotu the missinformation
Username: Invain
Michigan United States
Post Number: 2008
It is quite noticeable? How come Jonathan has been saying about 3 db's then?
Walton, Ky
Post Number: 2063
mabye me you and jon have been thinking of adding a second sub without doubling the power lol
Username: James1115
Wilton, Ct
Post Number: 2337
exactly sub! if you cut the power in half when adding a second sub then thats where you get a 3db increase, but if you double the power(3db's) and double the driver(3db's) you gain about 6db's on average.
Walton, Ky
Post Number: 2064
that where we were lost lol
Username: Jonathan_f
GA USA
Post Number: 3676
3db gain if you use a ported box on the sub you have, double the amplifier power, or add another sub without adding power.
6db if you double the subs and the power.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 920
So double subs, double power and going from sealed to ported should yield about a 9 dB gain in output?
-Fishy
