Tweeters..
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 333
I had my tweeters taped to the door with "heavy duty" double sided tape. Well the tape didn't hold, in the heat, and the tweeters fell and had doors closed on them:-( My question, should I get the replacement tweeters from Infinity, the 10.5t or could I use another set? Like some nice soft domes? I like the sound from the Infinitys but I like to expieremnt too.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 335
I guess the real question would be, if I bought a different set of tweeters would I have to buy a crossover built for it?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 298
you shouldn't have a problem hooking another set of tweeters to thoes crossovers. if the new ones come with crossovers, you can try both sets out, see if you can tell any difference and go with what you like
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 344
Cool, do you have any suggestions for nice soft domes tweeters?
Stockbridge, GA USA
Post Number: 301
no, but i'd take some too if anyones got any, lol
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 44
Vifa makes a great soft dome.
D27TG-35-06
This is a 6 ohm driver.
IMO this tweeter is one of the best soft dome tweeters I've ever heard, for the price ($30). It compares to the Scan Speak ($70) and the dynaudio ($600).
Username: Jonathan_f
GA USA
Post Number: 3695
I was about to say CDT, which are Vifa drivers, BTW :-). Depends on how much you can spend.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 368
I got about $80 w/shipping for them.
