Crackle..crackle????4x6 question
Username: Vwgn
so i just put my brand new pioneer ts-g464or 2-way 4x6s in my 1980 vw scirocco my HU is a panasonic cq-hx1083u i dont know the power on the HU but my spaekers are rated 20w NOMINAL power?..is that rms and 100w max and they sound shi**y they crackle and dont sound like they are getting enough/too much power?...did i wire em wrong?..what should i check?..thanks
Username: Terps297
Potomac, MD USA
Post Number: 82
i'm having the same problem
Username: Vwgn
my head unit is 50w x4...the speakers say 20w rms 100 watt max...shuld i buy 4x6 speakers that are 60w rms? would that do the trick? is it just 50 watts rms? from the deck going to 20w rms too much for speakers even though they are 100w max?...thnaks..HELP!!!
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 246
That headunit most like puts out around 22 watts of power. You probably just wired them wrong or got a sh!tty pair of Pioneer speakers, not like it's all that uncommon.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 247
Excuse me I meant like 12 watts.. 12-16 watts, so that is not the problem.
Username: Pharoh
Bradford, Ontario Canada
Post Number: 105
Check your grounds and they are pioneer. I had a few and they were okay for temp use, but the Rockfords i have now are better
Username: Invain
Michigan United States
Post Number: 2026
MAKE SURE you have the correct filters set. If the speakers do work, make sure you have a High Pass filter on the speakers.
