Speaker potential
Username: Tpizzle
Post Number: 15
I am thinking about upgrading my speakers to infinity references in my alero. how big of a difference will this make is it worth the money? also how important is an amp for the speakers?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 314
Coaxials or Components? If you get the coaxials, you'll be fine running them off the HU. If you get the comps, you'll need a small 2 channel amp to power them effectively. Either way, Infinity is a good upgrade to stock speakers.
