NEED HELP BAD!!!
Username: Alpinex
Largo, Florida United States
Post Number: 8
i have 2 Alpine Type X's, 3000 peak watt and around 1500 RMS watts, which amp would make it bang the best SPL wise and what should i look for in amps to tell which will help speakers bang harder???
Username: Carguy
Post Number: 2347
Depending on your budget, try Zapco C2k 6 or 9 series, Arc Audio, US Amps, Orion HCCA 275G4, PPI 1200.2 art series.
If you have a small budget, then stick to MTX or JBL 1200.1.
If you want to know what to look for in an amp, then read up on Orion HCCA G4 series.
Username: Loc_out
Post Number: 54
Isaac do you have the link to Orion HCCA G4 series.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7583
no longer made.
check ebay
Username: Carguy
Post Number: 2365
There are couple of Orion HCCA 2100 on sale at eBay right now.
