Carbon fiber enclosure
I had a friend who makes carbon fiber parts ask if carbon fiber could be used to make a good speaker enclosure. I know that fiberglass works and it is very similar.
Anyone ever heard of a carbon fiber speaker box? The lighter weight might be good for a car's performance.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7545
too brittle.
you could cover an enclosure with CF, but not use it as the main load bearing component.
fiberglass is good if it's at least 5 to 9 layers thick, but still flexes more than good old MDF does.
f'glass is just useful for it's maleability.
subless
so does that mean MDF gives better SQ than fiberglass?
