How do I install....
Username: Gorango27
... a Line Output Converter onto a 2000 Toyota Camry LE? Thanks in advance.
Username: Byrumjr
Post Number: 194
The Line Output Converter should have left channel and right channel wires. You just hook them to each channel. I hooked it to the back two speakers in the trunk.
Username: Gorango27
Directly to the speakers? So, its as simple as connecting the left and right channel wires to the wires that connect to the speaker? Its amazing how one can over look the simple things.
