Qes is the electrical factor. Qms is the mechanical factor. Qts is the total Q.
To learn more about small and large parameters, I suggest you buy a David B. Weems speaker building book. David's books will blow you away. After you read and understand these books you will laugh at all the myths that are out there. You will no longer be taken advantage by a salesman selling you the wrong item.
