Type-r 1221d or 1241d?
sebastian m
i want to buy two alpine type-r subs and i don't know what should i buy: two 1221d or two 1241d, in order to hook them to a jbl bp1200.1 at 2ohm.
isn't the jbl going to overpower/burn them?
Username: Its_bacon12
Post Number: 178
that amp will put 600w rms to each sub so yes it will overpower them and rip them to shreds, get the bp600.1 and use that to run 2 TYPE-rs and it wont matter whether you get dual 4 or 2 ohms
