How big of an amp can i use and be safe?
Jordan James
I have two 15" Pyramid subs 600 Watt RMS Power each 1200 Watt Peak Power each 4 Ohms Impedance what is the most watts i can run to EACH ONE with out damaging them?
with a ported box
Username: Mad_at_madd
Chico, CA USA
Post Number: 8
In theory you can run an amp with a 1200 watt RMS at a 2ohm mono load, if you wire the speakers in parallel. However, if you are going to do this I would recommend running something like a 1200watt sound storm or some other lower quality brand, 1200watt amp.
I had a 1600watt sound storm at one point running two Alpine type E 12's they were 4ohm single V.C. subs. They had a RMS/peak of 250/500 and the Sound storm pushed them fine. However, when I bought my 500watt memphis, which should have been safe for the speakers according to their rating, I blew one of the speakers within 3 months time.
Jordan James
are you saying run 1200w to each or one 1200 watt powering both subs?
Jordan James
Username: Invain
Michigan United States
Post Number: 1946
No offense, but what he's saying is that if you run 1200 watts to them, make sure you get a crappy amp to match the crappy subs. A crappy amp won't push near the 1200 watt's they say they can, nor can your subs take near the 1200 watts they say the can.
Chico, CA USA
Post Number: 13
Yeah, what Joe said.
