Whats up with this whole thing being blank?
Username: Kenwa
Post Number: 108
all i see is folders but no posts, why is that?
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 488
same here thats all i see, also
Username: James1115
Wilton, Ct
Post Number: 2259
me too I hate when this happens!
Username: Jmloughrey
Farmington, CT
Post Number: 1178
yup same here...maybe they are flushing the system?
Username: Kenwa
Post Number: 109
well im glad its that way for you guys too, i thought my computer was messed up or something
Farmington, CT
Post Number: 1179
yup thought that too....i almost threw it on the window...i really gotta scan for spyware again..havent in like 3 weeks...
Username: Bigdanman
The OC, CA USA
Post Number: 25
mine also!!!
Farmington, CT
Post Number: 1180
well...thats why my computer ran like a one legged man...39 new objects were found during my adaware search...
Username: Langner
Madison, South dakota US
Post Number: 66
thought my computer might have been screwed up also
Username: Kenwa
Post Number: 110
lol, well while you guys are here i have a few questions, the first one started the other day when alpine something told me that if you have 2 dual 4 ohm subs and you wire them individually for a two ohm load each and hook them up to separate channels on a 2 channel amp that the amp sees a one ohm load, is that correct?
The other thing is a am looking for one 15 inch sub, im thinking in the $200 range, i want to use the soundstream amp i have, it is 600 watts RMS by one bridged at 4 ohms
Farmington, CT
Post Number: 1181
if you wire 2 dual 4 ohms subs down to 2 ohms each sub and run each sub to its own channel on an amp the amp sees a 2 ohm load on each ahcnnel...if you were to wire to bridge the amp at this point you'd see a 1 ohm load which i wouldn't reccommend putting on just any any 2 channel amp...
Username: Kenwa
Post Number: 111
ok thats what i thought, but alpinethumping or something like that must not know that
Farmington, CT
Post Number: 1182
sometimes its just hard to explain stuff through typing...oh well....
yea this board being blank is starting to piss me off...
Username: Langner
Post Number: 67
are soundstream amps good?
Username: Kenwa
Post Number: 112
yeah i know what you mean
Username: Importrapist
Savannah, GA U.S.A
Post Number: 150
what are you talkin about??? Its fine i see everything...................................................................... ................................................................................ ..........................................ha ha ha i had ya thinkin for a sec (sorry im just really really bored)
Username: Langner
Post Number: 68
what is a good amp to power 2 12 inch eclipse subs bcuz i dont know...im thinkin 1200 x 2 but what kind of amp and i dont wannt spend an arm and a leg for it
Username: Kenwa
Post Number: 113
What eclipse subs are they?
Farmington, CT
Post Number: 1184
i'd say your best bet in that case would be to get one of the older orion xtr 2100 amps...the big red one...they can be found for about 300 on ebay.... other then that i'd say about the only option you've got left would be the newer orion 2400d or run an amp to each sub....
either way you're gonna need a hell of a charging system to run that setup...
Username: Kenwa
Post Number: 114
I like the soundstream amp i have and i have never had a problem with it but there are better amps for sure.
Username: Balls573
Winona, Missouri U.S
Post Number: 21
I need new components, noone can reply to question i posted cuz the damn forum is screwed up. I want very little bass from my speakers but crystal clear highs. I am only putting a new component set in the rear. They will be MB Quart Premium but what size should I get? I want a little bass but mostly highs should I get 6.5" or 5.25" components?
Username: Balls573
Post Number: 22
I wanna put new components in the rear of my jimmy. I want a little bass but mostly highs. Should I get 6.5" or 5.25" components?
Username: Fordpwr
Los angeles, CA Usa
Post Number: 193
FFuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu[[kk thiiiiiiiiiiiiiiiiiiiiisss $hiiiiiiiiiiiiiiiitt
Username: Fordpwr
Los angeles, CA Usa
Post Number: 194
FFuuuuuuuuuuuuuuuuuuuuuu(k thiiiiiiiiiiiisss $hiiiiiiiiit
Username: Fordpwr
Los angeles, CA Usa
Post Number: 195
FFuuuuuuuuuuuuuuuuuuuuuu(k thiiiiiiiiiiiisss $hiiiiiiiiittt
Farmington, CT
Post Number: 1185
you could get bass blockers for the speakers not allowing them to get bass of any kind....they'd just produce the highs....
Username: Balls573
Post Number: 23
I got some, they didnt work. My Mbs in the rear now are Discus and my fronts are premium. I want to get Premiums for the rear. Would there be that much of a difference in 6.5" and 5.25's? If so what should I get?
Farmington, CT
Post Number: 1186
probably not that youd really audible notice, go with whatever you can fit easily...i personally have 6.5s in my doors and i'm very pleased with them...they have great highs and the bass isnt very much at all....
Username: Kenwa
Post Number: 115
How long does it usually take for this stuff to get fixed?
Farmington, CT
Post Number: 1187
no idea, never seen it happen before, they are probably just updating a whole bunch of stuff, i'd say by morning it should be good againm, if not...just wait longer...i gotta get to bed though, big math test in the AM...
Username: Disturbedpriest
Post Number: 65
Hey yeah whats up with the forum? but i got a question i want to start my own stereo shop, here where i live and wanted advice.. Jonathan don't you own your own? or do you work for one? I have been talking to the banks and the town hall here in the town trying to get a loan started and some gov. help, my dad ran his copier machine buisness for 12 years (until he became a quadraplegic) and is trying to help me.. but i just wanted to know how hard it is to run a audio shop. I am a copier tech, and i have been doing system installs since the 6th grade, but i am also taking classes to be a better installer and i am really serious about my own buisness.. so any help would be awesome. ty in advance.
Moderator
Username: Admin
Post Number: 300
All is fixed. Sorry for the inconvenience.
Username: Subfanatic
Walton, Ky
Post Number: 2008
thank you
Username: Mcazayoux
New roads, La United states
anyone know how to find your own posts. i made my own a few minutes ago and i can't find it
Username: Mcazayoux
anyone?
Walton, Ky
Post Number: 2018
yea i know, i cant find mine eitehr
Username: Mcazayoux
sry my own thread
Username: Kenwa
Post Number: 124
same here so i made it again, so if you guys see the same post twice, my bad
Username: Mcazayoux
Does anyone know?
