Fuzzing noise in speakers?
Username: Langner
Madison, South dakota US
Post Number: 74
hey i jus put in a sony deck cuz it was free and it is now making a fuzzing noise in my speakers and it never did it b4 when i had the radio in so i was jus wondering if somethin is wired wrong or if it is just the cd player cuz i had it professionally installed so i dont think it would be a wiring problem but hey yah never know:-)
Username: Invain
Michigan United States
Post Number: 1967
Bad speakers/bad deck/bad ground
could be a number of things
Username: Langner
Post Number: 75
well it never did it when i had the radio in so it shouldnt be the speakers so im think the deck or the ground?
Username: Invain
Post Number: 1968
Yeah, make sure the ground is short and connected cleanly.
Username: Langner
Post Number: 76
should i connect the ground to a bolt or something bcuz it is connected to the ground on the harness now and it sounds like sh.it and it is gettin to me so i will pry check the ground out
Username: Invain
Post Number: 1969
It should be connected to a solid metal surface, free of paint or anything else.
Username: Langner
Post Number: 79
The ground is not the problem i figured out tonight it is the deck when i turn the EQ off on the hu it stops fuzzing and when i turn it to jazz or rock or nething else it will start up again and i bought it at ultimate electronics...And THEY ARE CLOSING in a couple weeks so i gotta get that figured out
Username: Invain
Post Number: 1980
Bad luck man. At least you figured out what the problem was.
