Need an Amp Wiring kit
thasource42
i got a 2001 isuzu trooper and i bought a JL audio 1000/1 amp and 2 jl audio 12w6v2 subs . i bought a 2 farad capacitor also. are there any other accesories i need? also can anyone show me a good kit to buy for my amp? thanks in advance
Username: Loc_out
Post Number: 40
www.knukonceptz.com
Username: J_dog
I think you should just get a reg amp kit but get a 4 gauge power wire and a bigger fuse.
Username: Suleman36
Post Number: 597
Im gonna be running a total of 1000 watts rms from 2 amps. Zapco500m - 700wattsRMS mono amp and the ppi art 300.2 amp - 300watts rms. The Zapco is 40A fuse and the ppi art is 30A fuse. What amp kit should i get from www.knukonceptz.com ?
Username: Suleman36
Post Number: 613
i guess now its gonna be the 500/1 instead of the zapco 500m because the avalanche wont work with the zapco cause the zapco is 700x1@2ohms and the avalanche 15 is dual 2 ohms i think so ill have to stick with the jl 500/1.. i whould love to use my zapco if i could wire the sub that way but i heard i cant.
