Overheating Vent Problems
Username: Edown
My KX550.2 amp keeps overheating! I have it hooked up to a Kicker L7 15 and it's running off of a Pioneer DEH-P6700 (I believe) deck. I think I have the gain up too much or something. Any suggestions?
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 882
First make sure you have that 15 wired to present a 4 ohm load bridged. I hope you have the 2 ohm DVC model with the voice coils wired in series. If not thats your problem.
Otherwise turn the gains down.
-Fishy
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 263
what Fishy said, or if you have the amp where it can't get good air flow, summer can cause problems to amps under seats and such
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 20
Check your power wire guage.
Username: Edown
I have a 4 gauge wire, but how do I know if it's bridged, or if I have the 2 ohm DVC model? Also, does my amp have enough power to push the 15 or is it lacking? Would that make it overheat?
Username: Edown
Also, what can I do to make my Kicker KX550.2 amp push the 15 inch L7 the best? What kind of wiring?
