Dust creeping in behind CDA9831 front display.
BusterDust
I've had this HU for a few months now, and i love it. But lately i've been noticing some lint and dust creeping behind the screen and right on the inner display!
At night it is not visible..but during daylight, the HU looks ugly,old and worn out.
Anyone else has the same problem?
I cant see any openings on the faceplate itself which the dust may have crept through though.. was the dust sucked in from a cooling fan on the back of the HU or somthing?
Anyone know how to stop this? I would be extremely greatful.
Username: Illuminator
Post Number: 59
It's almost inevitable! And yeah, i've had the same problem with many of my headunits...I normally just take the faceplate apart and clean it with a static-free wipe or something that won't damage the display, although you might not want to go that far.
Username: Kklagge
Post Number: 110
your 9831 has a cooling fan on the back of the HU?
Username: Bnh142
Post Number: 68
You usually just need to remove three screws on the back of the faceplate and then carefully pry the faceplate open to access the screen. Dust has a habit of finding its way back there somehow.
BusterDust
Thanks guys, will it damage the display if i use normal lint-free cloth? Is it safe to use compressed air?
kklagge:
Didn't bother to look.. Just thinking up possible causes heh..there had to be something causing the dust to build up behind the display :-)
Post Number: 65
It will be fine, the compressed air would probably be the best idea.
