How many amps
Username: Purplehase_bong
BC Canada
Post Number: 219
does a 400 rms amp pull?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7544
class D, about 40A
class AB, around 47A
that's at peak output
Username: Suleman36
Post Number: 565
Ok question? should i run my jl 500/1 or my zapco referance 500m class a/b mono amp??? the zapco does 500rms at 4ohms and is underated and can do 538rms and at 2 ohms it can do 700rms. The fuse rating is 40A for the zapco though. Which one of these amps whould be more efficiant if i run it to a avalanche 15 800 watt subwoofer.????? my stock alternator is 80 amps and im also running my ppia300.2 for componants.. and i will use my batcap 800 stereo battery in the back..thanks
