I'm going to be getting one Atlas 12" or 15" for my ford range extended cab. If i get the 12" it will be in a 2 ft^3 tuned to around 30. I am looking for an amp that puts out 300 watts rms at 4 ohms. What amp would you suggest for this sub?
go with the jl 250/1 amp. Excellant amp thats underated and will give you 300watts clean power. Good sub choice by the way. I heard it slams in a ported enclosure with 250 watts.
Excellent choice, I plan on getting one for my truck as well. Have you talked to JW about the Atlas? He has one and can give tips on the adjustable Qts.
