RE sub question
How would two SE 12" or 15" sound? Would this be comparable to a single SX 12 or 15? Do you think 500 clean watts is enough for the SE in a ported enclosure? Thanks!
also, if you had to take a wild guess at an SPL level, what do you think 2 15" SE could reach in a ported enclosure? 140?
Username: Suleman36
Post Number: 495
good question..i am interested in the RE SE aswell or the SX. A one subwoofer setup and go ported. I have the jl 500/1 amp and a ppi pcx2200 that does 800 watts rms x 1 @ 4ohms bridged to use.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 480
2 SE's could match 1 SX due to cone area gain, but thats depends alot on the install vehicles,enclsoures, power and so on. but SX's can get brutally loud.But the SE takes home the trophy in the sq department. but then again thats more personal opinion. 500watt rms FOR EACH SUB should be enough providing that the enclousre is built to spec. And i think Se's are capable of doing 140's yes. And for MO, if i were you i'd get the SX and use the ppi
Miami, FLORIDA USA
Post Number: 481
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 273
Just get the X.X.X.
