What do you think......
CrazyInsane
What do u think would hit harder while still sounding good?
2 12" eclipse titaniums with 600 watts goin to each one, or 4 atlas 12" with 300 watts goin to each?
CrazyInsane
if both setups were in a ported enclosure*
Username: Subfanatic
Walton, Ky
Post Number: 1965
id take the eclipse, acuse im an eclipse freak
Username: James1115
Wilton, Ct
Post Number: 2254
Atlas' just because they would be powered more efficiently.
CrazyInsane
haha aight thanks sub..... anyone else?
Username: James1115
Wilton, Ct
Post Number: 2255
it also depends in what type of enclosures you would be running them in.
Username: James1115
Wilton, Ct
Post Number: 2256
sealed vs sealed it would be close because the TI has much more x-max but the Atlas' have more surface area. Ported I would have to give it to the Atlas' because they have the XBL motors and they are very strong.
CrazyInsane
aight thanks james!
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 239
Plus you can customize the Atlas's sound with a potentiometer. I would take the Atlas's.
