How do i hook up 2 amps with out running more cords
Username: Devin_wyngard
Greenville, Wi Usnited states
i have a power acustic 980 watt max and with 2 12inch duals and i want to put 2 more 12's in with another amp but i do not know how to hook up another amp with out running all new cords. the thing i do know is that a distortion block i can use for the 4 gadge power wire but can i run 2 980 watt max amps off of that??
Username: Smokeysmoke420
well u can use a distibution block to separte the power wires then the rem wire can be ran off the 1st amp into the 2nd one rca's if your and dosnt have a set coming out you will have to by a y connector to and in the other rca wire as for ground you can ground that out
