Cavalier original deck and subs?
Username: Xstevex83
Post Number: 8
I was just wondering in anyone knew if you can hook up subs to the original cd player in a 2001 cavalier. it sounds really nice but I have no idea if it has the pre-outs. or do I need them?
please help
Username: Illuminator
Post Number: 55
You can get a line output converter that converts your high level (speaker outputs) to low-level (RCA outputs). They look like this: http://www.pac-audio.com/products/loc.htm
This probably isn't as desirable because you're going to get more distortion and the frequency response isn't as good.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 252
Spend some extra bucks and get a deck. It'll be more worth it in the long run.
Username: Xstevex83
Post Number: 9
thanks alot, I just didn't know if I would have problems or not. I just don't have the money to buy the deck right now, but I have the subs and amp from my old car.
