Memphis Belle amp question
Username: Onthelow
hello everyone. im thinking of buying the memphis belle to match up with the 13w7. i want the belle because its capable of powering the 13w7 at 1100w rms and push the my components at 75w /4. it should make for a real clean install. or should i stay with the JL 300/4 and buy the JL1000/1. just looking for some opinions before i make this purchase. thanks
Username: Onthelow
anyone?
Username: Glasswolf
Post Number: 1384
Memphis makes very good amplifiers.
It'd probably be a cheaper solution to the JL amps, though the JL amps might be slightly better.
Either way you'd have a good system.
I like Memphis' higher end stuff.
Username: Onthelow
thanks GlassWolf, the main reason why I want the the memphis is primarily the install and trunk space & it looks good lol. it packs everything in one 5 channel amp. the cost here would be about the same. thanks again, I believe i'll go with the M Belle...
