How much sound deadening do I need?
Username: Dpaw20
FL USA
Post Number: 70
Im planning on getting some eDead sound deadening just to stop the rattling, and later do the whole car. My trunk is rattling and rear doors rattle a little. How many sq ft of the stuff would I need without any left over because I dont want to waste money. Seems like 100 sq ft is A LOT. Should I just get 50/60? I dont know much about instillation but that seems right. Does anyone suggest otherwise?
Username: Sony224422
Deep River, CT US
Post Number: 138
it depends on how big your trunk is.. and doors and whatever else you want to dampen..
Username: Dpaw20
FL USA
Post Number: 71
its a jeep grand cherokee
Deep River, CT US
Post Number: 139
well then you could try to measure the back door, and the sides of your car and the bottom underneath the subs. Also, you should try to dampen the roof because i know my two friends who have jeeps and subs, there dome lights have fallen off from the vibration. When you measure it out, figure out how many feet you need and order.. 100 Sq feet sounds like alot but i don't think it is..
