PPI pcx-1250 or Orion 6002
Username: Goon
Post Number: 74
I'm torn between these two amps. One of them will be pushing 2 infinty kappa perfects 12.1D. they are rated at 350w rms, 1400w max. Which one do you think will get the job done better? The PPI will be doing 250wrms to each sub, and the orion will be doing 300 each sub. the help is apreciated, thanks guys.
goon
Username: Carguy
Post Number: 2219
I would go with PPI cause new Orion amps aren't as good as their previous ones.
Username: Goon
Post Number: 75
yeah, I have heard many good things about there older models, i assumed the new ones matched up as well. Thing is, I'm not too sure i want to push them 100w under rms. But i would like to keep the amp under 200$. Any other suggestions? I've been told that you won't get maximum performance from the subs if you run them under rms. thanks again.
goon
Username: Carguy
Post Number: 2220
If you're lucky, you might be able to get Orion HCCA 250G4 amp around $235. It is 800w rms.
There are other PPI PC/PCX series that will do 600w rms.
Username: Goon
Post Number: 77
Hey thanks Isaac. Do you know wher I can find that amp for a decent price?
goon
Username: Carguy
Post Number: 2238
Someone on here was selling the PPI amp. Look at "zapco" amp for sale posts. One of them will have his name and email address.
