4 channel amp to one speaker?
Hi, i was wondering if you can wire up a 4 channel amp to one sub, the amp is a Crossfire CFA-404S 4x100 rms and the sub is a eclipse 8810 dvc.
Username: Carguy
Post Number: 2271
That's a sure way of blowing your amp and the sub.
Chay G
So i can only bridge using 2 channels on the amp?.
Username: Carguy
Post Number: 2272
4 channel amps will bridge into 2 channel amp, 2 channel will bridge to mono.
If you get confused, think of 4 channel as 2 2 channel amps.
Chay G
cheers mate thought as much. thanks for the info.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 206
It would be a nice light show
