RCA wires
Username: Blindmp2
Post Number: 21
does the quality of RCA wires really make a difference or is it just looks? if so have u noticed a difference?
Username: Kklagge
Post Number: 91
Quality makes a big difference...notice I said quality and not cost...in my humble opinion the ones sold by knukonceptz are very good for the $$
Username: Blindmp2
Post Number: 26
thanks for the advice
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7471
the quality makes a difference in shielding and noise rejection mainly.
resistance also has an effect on how well the cable carries a clean signal from one end to the other.
I agree that KK's cables are good. I use their twisted pair cables. I just wish they'd used gold ends to avoid oxidation.
Username: Msully701
Stratford, Connecticut US
Post Number: 59
hey I have the most expensive ones at radio shack and its a radio shack brand its a think black wire with gold ends, they good?
Username: Msully701
Post Number: 60
hey I have the most expensive ones at radio shack and its a radio shack brand its a thick black wire with gold ends, they good?
