Like
Best speaker choice
Username: Tpizzle
Hey i have an oldsmobile alero, it has just the original stock speakers. I want to updgrade, what would be the best choice, ive heard alot about infinity's. If i only have enough funds to replace either the front or back which should i do for better sound difference? any suggestions? thanks
Username: Abew330
Camarillo, Ca Usa
Post Number: 55
wat size speakers u got stock? jensen alright.. fosgate Focal.. theres some pioneer 6.5 3-way speakers.. does anybody know how they sound?
Username: Tpizzle
they are 4x6 in front, 6x9 in the back. which would sound better if replaced? ALso does anyone know what kind of bass good speakers put out (with an amp) or do you need to go all out with a sub for that?
Facebook
Shop Related Deals
Directory
