Sub Box
Username: Grandam95
Willoughby, Ohio Lake
Im planning on making a sub box later today and i wanted to know what was the best way to seal the box when i run the wires to the amp.I wasn't going to use terminals I was planning on just drilling a small hole in the back of the box and sealing the wires with caulk or something think this is a good idea?Anybody got a better one?
Username: Araknid
BOCA , FL U.S.
Post Number: 386
you can do that no problem.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 232
any kind of sealant thats not acid base (will corode wire and cause problems) will work fine
Username: Goon
Post Number: 72
I did that with my last box. It worked fine for me. Just remember to give the caulk a chance to cure before you go using it.
goon
