Advice on system
Username: Msully701
Stratford, Connecticut US
tell me if this is good for a person who just wants to have a decent system no comp.
the amp:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5764159323 %26
the subs:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777%26item%3D5764386912 %26%26
the capacitor:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=75388%26item%3D5764769872 %26
prolly going with alpine or clarion for headunit. tell me what ya think
Username: Taylor17
Kopperl, Texas
Post Number: 1248
That will be pretty loud! Why are you getting a cap???
Username: Msully701
because you need them? so my headunit wont dim on each bass hit? I think I need 1 right lol?
Username: Msully701
I heard this site got sick sub boxes, tell me what you think: http://proboxrocks.com/superbass/212SQSPB.shtml
Username: Taylor17
Kopperl, Texas
Post Number: 1252
I've never actually had any experence with them... but I've also heard that they are great boxes.
If you're lights are blinking... its because you're alternator isn't strong enough. The best way to fix that, is to buy a HO alt. Not to mintion, you won't have to worry about you're alternator going out on you. That sucks, believe me!:-)
Username: Msully701
Post Number: 7
eh it wouldnt hurt to have a cap they do help a bit
Username: Taylor17
Kopperl, Texas
Post Number: 1253
Actually, it just hides the real problem. If you're alternator already can't keep up with the demand of you're system, then you're going to make it try to charge a cap too!
I'm not telling you not to buy one, I'm just trying to tell you that you might need a bigger alternator, that will deffanently fix the problem.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 184
caps just help with amp reaction/responce time
Username: Msully701
Post Number: 8
well can ya tell me how to connect the subs to that amp? doesnt it need to be 2 channel to work?
Username: Msully701
Post Number: 9
aim me how to connect it if someone could thanks
aim:Msully70
Stockbridge, GA USA
Post Number: 195
this should help you with your wireing
http://www.jlaudio.com/tutorials/wiring/index.html
Username: Msully701
Post Number: 21
brandon I plan on wireing it to 2 subs at 1 ohm.the subs are dual 4ohm each. the amp says 1200watts x1 at 1 ohm. so if I hook up 2 subs. will it split the wattage evenly if I hook it up as 2dvc drivers with voice coils in parallel/ parallel?
