REALLY LOST kicker sub and box
kam
Hey i made a box for my kicker L712, i bought a terminal box.. which connects the speaker cable to the postive nd negitive side. But on my sub there FOUR places where i can put in speaker wires.. What do i do? i can connect two to the sub what about the other two areas i can put speaker cables.. heres a pic if one doesint up load..
http://www.lightav.com/car/kicker/solox2.jpg
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 210
sounds like its got dual voice coils, so you need to either wire the VC's in series (+ to - and + to -) then off of one VC to the amp. this will give you a 4 ohm load if its a dual 2 ohm sub or 8 ohm load if its a dual 4 ohm sub
or wire then in parallel (- to - and + to +) then off of one VC to the amp. this will give you a 1 ohm load if its dual 2ohm or 2 ohm load if its dual 4ohm.
depends on your amp.
oh and about that terminal box, i'd take it back and just drill you a hole in the box the size of your wire, use silicon sealant if your concerned about air leaking out. thoes boxes aren't needed and can cause problems.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 46
the reason the sub has 2 neg. and 2 pos. is so you can wire the sub to 2ohms 4ohms and 8ohms heres a link that might help http://www.jlaudio.com/tutorials/wiring/index.html also what kind of amp do you have
