Someone help me test
Username: 54danny54
Post Number: 124
will sumone take the same box, woofer, amp and everything and fill it the first time with polly fil and seconnd time with cotton candy and tell me what works better lol
Username: Jmloughrey
Farmington, CT
Post Number: 1094
are we talking red cotton candy or blue cotton candy? cuz we all know blue will yeild 7db more :-)
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 842
I dunno the rarefication/compression of the enclosure's air mass might in a humid climate lead to condensation which could turn blue cotton candy into a rather sticky and messy yet tasty glob of smurf goop.
What about popcorn?..... no butter of course.
-Fishy
Username: 54danny54
Post Number: 126
try cake lol
Username: Coolcardude
Or
Post Number: 26
i heard lamb chops produce quite a nice resonance.
somethingredicolousihavetomakeup
would putting a metal mesh grille over the port on a box change the dynamics of the port or would it be able to funchin the same as without the metal mesh
Username: 54danny54
Post Number: 132
id say if u bolt it tight enough it will perform the same
Farmington, CT
Post Number: 1096
be carful thought because it could possibly create port noise...
hmm i heard mexicans in a bandpass enclosure sound sweet.
Username: Tragedy
San Jose, CA
Post Number: 183
wow if this came from an unregistered guest or an anonymous then i would of figured someone was joking around looking for a laugh.
But really what would posses someone to put cotton candy in a subwoofer box? Was someone that wasted that they mistook it for polyfil or were just to lazy or cheap to buy $3.99 pillow stuffing. Just shred up a pillow or your sons or daugthers favorite stuffed animal. Just make sure the pillow isnt down =).
On a stupid note i here if you put water in your enclosure (just the fiberglass ones) you get more spl as the sound bounces off the water. But thats just what i heard.
